WiFi
Victoria32
Message 15 of 15
Good morning
We've had a problem with the Internet for a few days. We've had a BT engineer out to check externally - all OK; we've updated the wiring to and from the router - seems OK; we've run all the checks provided by TalkTalk - they say the connection to the house is fine, but the connection from the house is poor. We still have Internet TV. We've decided that the router is the problem, so I've ordered a new one, but at £110 I'm worried that I've done the wrong thing, or bought the wrong product. Any thoughts?
14 REPLIES 14
Message 1 of 15
OK, I've cancelled the router order for you.
Victoria32
Message 2 of 15
Thank you for all your help. We now have Internet.
Message 3 of 15
Can you add the account holders name in the private notes section of your profile, just so I can make sure I'm looking at the correct account.
Message 4 of 15
Hi Karl
The phone number is correct, the actual account holder is unable to use their mobile Internet to connect.
Message 5 of 15
Can you check the home phone number in your profile as this is showing another customer, could be a typo in the number.
Victoria32
Message 6 of 15
OMG! 😂 IT'S WORKED! We're back online! I can't believe it! 😂 What do I do about the router I've ordered?
Victoria32
Message 7 of 15
Tried it, no joy. 🙁 Still unable to find the router.
Victoria32
Message 9 of 15
No, haven't seen that before. 🙂 I'll try it.
Message 10 of 15
Hi Victoria32
Did you try factory resetting your current router using the pin hole reset for ten seconds?
Victoria32
Message 11 of 15
From TalkTalk. None of our devices recognise the router. It's not there to connect to.
Message 12 of 15
Hi Victoria32
I've optimised your connection and the line is now in sync at 20mb.
Where did you order the router from?
Victoria32
Message 13 of 15
I think I've done it, Debbie.
Message 14 of 15
Hi Victoria32
Please can you add your name and TalkTalk landline number to your Community Profile, we can then look into this further.
