Wifi Dropping out
rikrak
Message 9 of 9
I have a HG635 (software version: v1.14t, hardware version:G.1.01)router and recently I've noticed that the Wifi seems to just stop working.  For example my mobile phone (and the phones of others in the house) will switch to using mobile data from time to time and I have to reboot the router to restart the wifi service.  On other occasions my phone will connect to the wifi, but will not authenticate.  I also suffer from being able to connect to the wifi but having no internet.
These issues are intermittent and I can't spot any patterns in terms of time of day or heavy usage.
The wired connection to the router appears to work fine.
Is there anything I can do to diagnose/fix this?
Rik
Rik
8 REPLIES 8
Message 1 of 9
I'm really glad to hear this and thanks for the update 🙂
Message 2 of 9
I've had the new router installed for a few weeks now, and I can definitely say that it has made a difference 🙂
Thanks for your help
Rik
Message 3 of 9
Hi rikrak
I have ordered a replacement router for testing, please allow 24-48hrs for this to arrive.
Thanks @KeithFrench
Message 4 of 9
The customer has provided me with lots of screenshots & I can see breaks in the WiFi signal, but nothing to really point to WiFi interference. However, the signal strength in the 2.4GHz band is very low. The router's location is quite reasonable, so that isn't the issue.
TalkTalk, please can you consider sending out a replacement router to see if that solves the problem?
Message 5 of 9
Hi Keith
I've just tried to send you some screenshots via PM, but there seems to be a limit to the number of messages I can send!  I'll try again in a bit
Rik
Message 6 of 9
I will PM you a link for a guide of mine on Wi-Fi interference & initially look at the section called "Are you suffering from interference – prove it first". This section includes full details of Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots that I have requested in my guide (no photos please they can be difficult to read as text can get out of focus when zoomed), from the analyser you are using (also in my attached guide). Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large. If they are too small, I will not be able to read them & although I can enlarge them, this just puts the text out of focus. If you prefer PM them to me. If you do PM me, then please add a link in there to this thread, so as I can find it easily.
rikrak
Message 7 of 9
Hi Keith,
That would be useful - could you send me the guide?
Rik
Rik
Message 8 of 9
The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
