Wifi Extender kit / Powerline adapters
heavegar
Message 2 of 2
Hello
I have recently purchased the Wifi extender kit from the online store to try to boost my wifi signal.
The problem is despite following the instructions issued by TalkTalk help I cannot get the original powerline adapters to connect.
The original powerline adapters are the white ones with the power through socket D-Link DHP-P326AV
The Extender kit is D-Link DHP-W611AV
Should these two work together or have I fallen for the TalkTalk trick and been sold another pup, which I wont be able to return?
And I will have to chose between the TV package or the wifi ?
Oh hang on the TV package is disappearing next year anyway, but I do have a TV which is connected to the internet because the wifi is pants  (hence the Extender purchase, which funnily enough has not improved the wifi signal yet but I can stick a cable in it)
Much appreciate any help and advice.
Thank you
Heavegar
1 REPLY 1
Message 1 of 2
Hi heavegar
Apologies for the delay.
Have you had a look at this help page? Fix a problem with your Wi-Fi Extender Kit
