Wifi constantly dropping and hub showing too many devices
lipscomberise
Message 3 of 3
have follow the 'step-by-step guide for help identifying and
fixing issues with your connection' none of this has worked
I have tried different channels and still this has not worked. Happening on all devices, internet one second and then gone the next, takes a while to come back up and then goes again
Any ideas?
I have follow the 'step-by-step guide for help identifying and
I spoke to talk talk on the phone last week and they told me it was because I had too many devices attached, they then told me that wasn’t correct and that it was actually  the channel that was the problem. This still keeps happening and I change the channel regularly. So I decided to test the too many devices theory, I changed the password and only allowed my phone and laptop to connect to the hub but I’m still having the same problems with the Internet dropping out and when I log in to the TalkTalk hub it shows that I have 11 wired connections however only one device is plugged into the back of the Router?
Message 1 of 3
Hi lipscomberise
Would you like me to send a different router for testing to see how the connection compares?
Message 2 of 3
So much will depend on how fast the speed is recorded by the router when you log into it & how your devices are connected to the router. However, by your subject title, I am going to assume that they are all wirelessly connected. Just changing Wi-Fi channels without first investigating the cause of the problem is very unlikely to give acceptable results.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
