Wifi disabled
Charmie90
Can connect directly to router, but wifi is disabled for some reason. Done the usual reboots and making sure WiFi is enabled in the dashboard. Seems other people have had same problem and it may be a faulty router. Can I get a replacement sent out please?
Hi Charmie90
Can you ass the home phone number to your Community Profile so I can locate your account and get a replacement out to you.
