Wifi is not
meganbricknell
Message 27 of 27
Our wifi has not worked since last Thursday (the routers it’s self is working) power light is solider and wireless is flashing. Unable to do a health check ourself as the account is not in our name (in landlords and can’t get hold of him) any suggestions on what to do?
26 REPLIES 26
Message 1 of 27
Hi meganbricknell,
I've sent you a PM
Skynet_TX
Message 2 of 27
Hi @meganbricknell,
Do you know what the phone number of your line should be, if you have some correspondence from TalkTalk it is possible it may be mentioned on that. If you do know what the phone number should be then try dialling 17070 and ensure it does read back that same phone number.
Hopefully the staff here will be able to get back to you soon, as it does sound like the next step would be an engineer visit.
Message 3 of 27
@Karl-TalkTalk @Skynet_TX can you help with this please
meganbricknell
Message 4 of 27
I am unable to create a password for the account to pass security for an engineer to come as I do not have the account number. What can I do? We haven’t had wifi now for almost 2 weeks, what’s the best option? Thank you
Message 5 of 27
Next option is to get an engineer to you asap.
I'll PM some details to you to allow this to progress.
meganbricknell
Message 6 of 27
Hello @Karl-TalkTalk, we received a new router, it still does not work and bought a phone which does have a dialling tone and you can ring out / receive call on it. Do you know what the next step will be? Thank you very much.
Message 7 of 27
Yes we bought a phone and it has a dialling tone and you can ring out on it
Skynet_TX
Message 8 of 27
Have you been able to get hold of a phone to see if there is a dial tone on the line ?
meganbricknell
Message 9 of 27
Hello @Karl-TalkTalk, new router has arrived (thank you very much) but still no luck with the wifi, set it up and just has a constant flashing amber light. Tried it in the test socked also and exact same. Thank you
Message 10 of 27
I've checked with the courier and the router is at your local depot with delivery scheduled for Tomorrow.
meganbricknell
Message 11 of 27
Hello @Karl-TalkTalk, we have had a letter with return your router but not router, is one due? Thank you very much
Message 12 of 27
No Problem 🙂
Try the router as soon as it arrives and get back to me here.
meganbricknell
Message 13 of 27
Hello @Karl-TalkTalk , no problem I will try this. Thank you very much for all your help!
Message 14 of 27
All usual tests are clear, so not seeing an issue remotely, but the router is not connecting.
I've a new router on the way so this can be ruled out.  Should arrive in the next 24-48hrs.
While you are waiting for the router to arrive, it would be good if you are able to borrow a phone handset from a friend for 2 minutes, just to check you have a clear dial tone.
meganbricknell
Message 15 of 27
Hello @Karl-TalkTalk, I have just done this now. Thank you very much.
Message 16 of 27
If you cannot remember the phone number or account number associated with your line, put the house number and postcode in the private notes section of your 'Community Profile' so we can search for your details.
meganbricknell
Message 17 of 27
Hello @Debbie-TalkTalk, yes I have tried everything 😞
Message 18 of 27
Hi meganbricknell
Unfortunately we need your account or TalkTalk landline number.
Have you you tried factory resetting the router using the pin hole reset for ten seconds?
meganbricknell
Message 19 of 27
Hello @Debbie-TalkTalk, the issue is we can’t get hold of our landlord who has this info. Is there a way of finding out the landline number in our apartment? Is there anyway around this? Thank you very much.
Message 20 of 27
Hi meganbricknell
We would need you to add your TalkTalk landline number or account number to your Community Profile so we can look into this further.
