Can someone please help with the issue. Not able to work from home
Hi,Have you tried rebooting your router or hub,turn off power to router or hub wait for about 30 seconds turn on again and let it reboot this sometimes cures the problem,the power on and off is a botton on the rear of the router,otherwise you will have to contact customer services,(GOOD LUCK WITH THAT)
Hi Priya86in,
I'm sorry for the delay in getting back to you.
We'll then look into this further. Please do not post this information on this thread Once you've updated your profile please post in your topic to confirm it's updated.
Hi I have tried that but it’s still not working and I have tried reaching the customer service but no one is available. Please suggest what to do.
Hi I have updated it. Request if someone can get in touch to sort out the issue thank you
Hi Priya86in,
Thank you and I'll take a look now. I've run a test on the line which hasn't detected a fault. Do you have a dial tone? Do you also have a different router that you can test with? If not then please let us know and we can arrange to send a replacement router for testing purposes.
Hi no I don’t have a different router. Can you please send another one . Thank you
Hi, by when do you think I can get the replacement router. It’s really urgent
Router orderd for you. Under normal circumstances a router is delivered in 24-48 hrs. With couriers busy with online orders increasing we are unable to specify an exact time frame.
