Wifi upstairs
Jj120
Message 4 of 4
Getting really annoyed with slow Internet and dropping out upstairs. We have a tiny house so don't really understand the problem?
I'm not tech savy I'm afraid, but the situation is really frustrating as I can't see a problem
Thank you
3 REPLIES 3
Message 1 of 4
As a general rule, the WiFi signal from a router travels best on the same floor as it & the one below, but not to the floor above. Hence why @martswain recommends putting it as high as possible. There are other potential problems, one of the main being the level of WiFi interference from other WiFi networks.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
martswain
Message 2 of 4
Put your router up as high as possible, for some reason they seem to radiate better at the same level and below the device.
Split the WiFi bands and connect the upstairs devices to the 2.4 Ghz band as that has better penetration through solid surfaces.
https://community.talktalk.co.uk/t5/Articles/Split-your-router-s-SSID-wireless-network-name/ta-p/230...
Message 3 of 4
Hi Jj120
Please can you add your name and TalkTalk landline number to your Community Profile, we can then look into this further.
