Wired connections red warning symbol
LukeDeAth95
Message 4 of 4
Recently I've noticed a red warning question mark '?' on wired connections when viewing My Devices on our TalkTalk router Wi-Fi Hub? Is anyone aware on how to fix this as since this has happened I've been having major issues with the router connecting to my DNS server (Raspberry Pi) via a direct wired connection. Everything can connect to the router and access internet (my PC is wired for example) but im wondering if the issues im seeing with my DNS server not being able to ping gateway is related to this.
3 REPLIES 3
Message 1 of 4
I'll answer in your other thread.
Message 2 of 4
The question mark just indicates it cannot identify the device fully, this will not however affect the function of the device or the connection.
LukeDeAth95
Message 3 of 4
Recently after a router reboot on our TalkTalk Wi-Fi Hub (version SG4K100130) I've noticed a red warning '?' sign under Wired connections on our online portal under 'My Devices'. Is anyone aware of what this actually means exactly, as recently I've also having issues with my DNS server (since the router rebooted) which is raspberryPi with a wired connection direct to the router. I'm wondering if these are somewhat related.
Has anyone seen this warning before and knows what its in reference too exactly?
