Wireless Optimisation (ASSIA)
12 REPLIES 12
I would like this turned off on my Sagem FAST 5364, as I need to keep the 2.4GHz connection on the same channel. I raised this problem on 4/2/2019, and there was no satisfactory outcome. Since then, another person has had the same problem, and the optimisation was turned off for his phone number. It seems impossible to get through on chat or by phone now.
I finally got through on "chat" but the technician asked me to reset my router back to factory settings. Due to my non-standard setup (I use my own dhcp server) it took me a few minutes to get back online, and chat is now busy again. A bit of a waste of time. Channel set to 1 now - I bet it's moved again by lunchtime. The wireless optimisation has not been removed. The agent didn't seem to know about it, despite my posting previous threads where this has been done.
Hi @dgahunt ,
The staff on this community are familiar with this type of request, so they will certainly understand what you are asking for !, they will be able to disable this behaviour for you.
It may take them a day or two to respond to this topic, it is best to not post any more in this topic until they respond, as any new posts can delay this topic getting to the top of their queue.
I can turn this off for you.
For feedback, can I ask why you want this turned off, is it affecting a specific device etc or need to be on a set channel for a specific reason etc.
Hi Karl,
thanks for responding. I use an Edimax wireless bridge to provide wired ethernet upstairs, enabling things like PXE booting, and operating systems without wireless capability. The way it is configured needs it to be on the same channel. It doesn't cause any problems, and is normally turned off anyway. See my original post on 4/2/2019 for more details. I have an old D-Link router I can use, but the wireless isn't as good as this newer Sagem.
Hi OCE_Karl,
have you done this for me? I suspect the answer is yes, as the channel hasn't changed for the last three or four days. If so, thank you.
Dave
Hi Dave
How has the connection been since your last post?
The router is now staying on the wireless channel I set it on. It hasn't changed since I last posted. It looks like the optimisation has indeed been turned off. I can change the channel myself if I have any problems. Thanks to anyone involved.
Hi Dave
That's great, thanks for letting us know.
Debbie 🙂
It was fine for a while, but is now switching channels again. It has done this twice in the last three days. I set it to 1, and it stays for a few hours, then switches to 11. If I set the other device to 11 as well, it will switch back to 1. I would like someone to fix this again for me, please, but if it doesn't get fixed this time, I'll go back to using my older D-Link router.
Hi dgahunt
Apologies for this.
Would you like me to send the Huawei WIFI Hub for testing, this does not use the WIFI optimisation.
Hi Debbie - sorry for the long delay in replying. I'd switched back to my D-Link router, which doesn't have this problem. I would love to get the new Huawei hub, and would certainly feedback any results, good or bad. Thanks, Dave
Hi dgahunt
The Huawei WIFI Hub is on its way, please allow 24-48hrs for this to arrive.
Debbie 🙂
