Wireless switch keep disconnecting
mik23pe
Message 12 of 12
I have sonoff wireless switch and i notice router keep disconnecting from the switch it require a roiter reboot after a day or 2
Any suggestions settings pls
11 REPLIES 11
Message 1 of 12
Hi mik23pe
I can see that Keith has offered some advice. Keith provides great support and advice on improving wireless performance.
Message 2 of 12
Have you checked this with a WiFi analyser in line with the help I have already offered you?
mik23pe
Message 3 of 12
Thanks Debbie
I tried it.today but its for some reason keep loosing connection
The switch is physically next and least populated band is selected
Any other setting can u advise pls
Message 4 of 12
Hi mik23pe
I've switched off the WIFI optimisation to see if this helps.
Message 5 of 12
You need to check the state of the 2.4GHz band as a whole, you could be moving it from a bad channel to an even worse one otherwise.
Please see the last two paragraphs of my reply in message #4.
mik23pe
Message 6 of 12
I tried to change the channel increase the lease but still the wireless model is sonoff basic the ip add is static
Not sure where else i can look
It keep disconnecting and i have to restart router everytime
Not sure what i m missing
Message 7 of 12
WiFi interference can affect any wifi device however close or far away from the router it is. This would be first step in diagnosing the problem, because the 2.4GHz band can be so congested, that it might be unusable in your area. I am not saying that it is that bad, I simply do not know without further diagnostics. It is also the most likely cause of the problem that you describe.
mik23pe
Message 8 of 12
Interesting the sonoff wifi switch is physically located next so it shouldn't have any prob
The ip address is also reserved
I am happy for suggestions
Message 9 of 12
Splitting the SSIDs (network names) of the two Wi-Fi bands does not help resolve such matters at all.
The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
mik23pe
Message 10 of 12
Thanks for the prompt response
Router is Huawei DG8041W
I have split 2.5 and 5ghz
Sonoff is wifi smart switch 2.5ghz
Message 11 of 12
What make/model of router do you have & what is the model number of this Sonos switch.
