Xbox 360/Live
eekie1979
Message 2 of 2
Hey, I've been having issues with my Xbox 360. As soon as I turn it on, my WiFi slows down and when I connect to Xbox Live it seizes up almost completely. Nothing else has this effect on my WiFi. When I switch the Xbox off, my WiFi is the slow for a day or two unless I do a hard reset. I've had a quick look in the router settings but can't see anything obvious 🤷🏻‍♂️Anyone got any ideas?
1 REPLY 1
Message 1 of 2
Is the xbox only connected via wifi, have you tested wired ?
Have you tried a pin reset of the router - hold a pin or paperclip in the reset hole at the back for 10 seconds and this will fully reset the router.
