broadband getting slower and more erratic
Wizz Kid
I am having very similar issues
https://community.talktalk.co.uk/t5/Broadband/Internet-Issues/td-p/2545233
Been happening for me since the 14th April, had 2 new routers sent to me plus 2 BT Open Reach calls but problem still not resolved.
hi Karl,
so far so good: up to 2.0mbps so far - and still stable.
Hi marqous,
Thanks for confirming 🙂
had a little wobble yesterday: went a bit slow and variable on the speedtest: 1.4mbps varying up to 1.6. resetting the router didn't seem to settle it, but later on it was back up to a fairly consistent 1.9 - 2.0.
1.9 today, and ping 47ms. when it's running well ping is <40ms.
Hi marqous,
Thanks for the update. How have you found the connection over the weekend?
hi michelle,
stability has been fine over the weekend, speeds fairly consistent: 1.9 - 2.0 mostly, occasionally see 2.1mbps, but nothing higher.
Hi marqous,
Is your router currently switched off at the moment?
Hi Michelle,
yes, sorry, i had a shortage of power so turned it off overnight - it's back on now and should be staying on for a few days at least.
down at 1.7mbps today.
thx
M
oh dear - down to 1.2mbps today 😞
connection still seems reliable - just slow.
still 1.2 today despite resetting. Any suggestions?
still only 1.2 today - have you given up on trying to fix this?
Thanks Devereux, that's good to know. I'm just wondering if they consider it as fixed as it is working, albeit slower that 'normal'
it's reached 1.3mbps today
You must be on a very long ADSL line to have such a poor speed. Is fibre not an option available to you? Forgive me if that has been mentioned before, but I didn't see it.
Hello ferguson, no, fibre not yet an option here alas.
 the phone line has in the past supported sync speeds of up to 3.9mbps, but in recent times talk talk/bt openreach have failed to maintain that.
when the old router failed a few months back they send a new one which improved things as it went up to 2.6mbps - which is fast enough for my needs tbh - but then things went flakey, which led me here.
they did send me another new router ( as said earlier in this thread) and it improved up to 2.1mbps, but over a week or so has fallen back to 1.2 or 1.3 (though still more reliable than the one it replaced).
clearly the line is capable of better that 1.3, so i.m still waiting for talk talk to work out how to fix it. although they seem to have gone very quiet on this thread...
Or perhaps i should see if i can claim the £8 /day deveraux mentioned - maybe talk talk would would try harder then. but am not sure how i claim it if they don't reply even on here - it's not like they're answering the phone any more.
Wizz Kid
@marqous
There does seem to be the attitude of we can't fix this so if you can just pay extra each month for Fibre that will fix the problem and solve your problem, meaning you end up paying for fibre which you don't actually need which costs you more each month so TalkTalk don't have to fix the problem that actually exists in order to resolve the problem in the first place.
We are also having this problem. Also we are vulnerable adults working with vulnerable people on line who rely on our connections. This is highly stressful. We managed to speak with someone a month ago who confirmed there is a fault in the area but did not specify. It has been impossible to talk with anyone since and the fault has not been sorted. It feels like a very shoddy service and paying for something we're not receiving is immoral. All tests show that we can't update either to a faster broadband because Talk Talk is unable to deliver that in our area-almost central london.
@Neasden9 Please start your own topic and the support team will look into this for you.
@marqous I have re-escalated this for you.
Thank you ferguson.
I wouldn't mind being upgraded to fibre to solve the problem if it were an option TBH, particularly as the cost of fibre isn't much more.
But it is frustrating when you're paying through the nose for old-fashioned wire broadband and they don't even try to maintain it to a reasonable proportion of it's potential; as i said, this line has run at 3 times it's current speed in the past (currently 1.3mbps).
And i would settle for 2 times it's current speed, which it did achieve with the previous new router before it went flakey. Surely that's not too much to ask.
 As the 'new' new router has dropped to 1.2/1.3 from a peak of 2.1 - similar to the 'old' new router, (and the old router IIRC) i suspect the fault to lie elsewhere ( the exchange? - The phone is still working fine).
Hi marqous,
Apologies for the delay
Is your router currently connected to your test socket?
How many telephone sockets do you have? Do you have anything connected to your telephone sockets in addition to your router
Is the router situated close to other electrical devices that could be causing interference? Is it connected to a multi-socket electrical extension lead shared with other device?
hi chris,
Router is currently connected to the test socket (via the supplied microfilmer), as is the cordless telephone (bt graphite DECT type). That is the only phone connected; there are no extension phone sockets. The phone basestation is a couple of feet from the router at the moment but could be moved further away.
Not sure what else could be causing interference - certainly not anything that's powered all the time.
The router PSU is connected to a multi socket ext socket along with the cordless phone psu, and, sometimes, other electronic equipment.
