fibre broadband problems
18 REPLIES 18
oldun1
since "upgrading" ? to fibre 35 on 6th february i am having to reboot router at least once sometimes twice a day.Had 50min phone call on 17 february to tech help which did little to help,only rebooted router and said monitor system which i have done, also told me line was being optimised and could take 10 days. Still no change, Speed ok all day after reboot, appr 24mb/ps but drops off rapidly after 6pm to around 0.34mbps the following morning. Speed comes back up after another reboot, any suggestions gratefully accepted.....ps i am 77years old and not a techie so simple is better.....thanks
Skynet_TX
Hi @oldun1,
Then they will hopefully be able to respond to this post within a working day or two.
oldun1
Have updated profile, hope its ok...thanks
OCE_Michelle
Hi oldun1,
I'm sorry to hear this and I will take a look now. I've run a test on the line which has detected a possible fault. Just to confirm, is your voice service ok with no noise on the line? If the voice service is ok then we can raise this over to Openreach to investigate the broadband issue.
oldun1
Hi Michelle,
No background noise on phoneline,just problem with broadband.  Speed ok during day 23mb/ps till around 6pm. then starts dropping overnight untill following morning when i have appr.0.5mb/ps
but goes back to 23mb/ps after daily reboot. been like this since upgrading to fibre 35 on february 6th.
OCE_Michelle
Thanks for confirming this. I've raised this over to Openreach now to complete an external line investigation. If you don't hear any more over the next 48hrs then please let us know and we can re-check for an update on the fault for you.
oldun1
Hi Michelle,
Thanks for update,will keep watch for next 48hrs, and let you know what happens. appreciate your assistance
Thank you.
OCE_Michelle
oldun1
Hi Michelle,
Just had phone call from Open Reach,they say line is ok to telegraph pole so they suggested me requesting a new router to try, seems to think that will solve problem. Can you arrange that for me please,
ps. do i have to pay for new router ??
                  Thanks a lot....... Dave
OCE_Debbie
Hi Dave
The replacement router is on its way, there is no charge for this.
Please allow 24-48hrs for this to arrive. Let us  know how the connection compares with this router.
oldun1
Morning Debbie,
                           thanks very much, will let you know situation with new router when it arrives
                               thanks again......Dave
OCE_Debbie
oldun1
Hi Debbie,
                  New router just arrived and installed. Will monitor for a few days and let you know if all is ok. Thanks for all your help,very much appreciated
        Thanks .....Dave
oldun1
Hi Debbie,
                 Forgot to ask, do you need old router back or shall i recycle it from my end,
                                                           dave
OCE_Michelle
Hi Dave,
Great, thanks for the update. Yes please can the original router be returned when you have finished your testing. Did you receive a router returns bag?
oldun1
Hi Michelle,
                  Yes, have got returns bag.will return old router as soon as posible,not getting out much at moment. New router seems fine so far. Once again thanks for all your help with this issue, your doing a great job,
                                                   Thanks.....Dave
OCE_Michelle
oldun1
Hi Michelle,
                    new router seems to have solved my problem.speed is constant at 19/20mb/ps
which i am happy with, so all is well. Thanks again for all your help with the problem,you've all been brilliant,
                                     thank you......Dave
OCE_Michelle
Hi Dave,
I'm really glad to hear this, thanks for the update 🙂
