my powerline network connectors have stopped pairing.
5 REPLIES 5
My (rather old) powerline network connectors just stopped pairing a few weeks ago.  I have tried everything from re-booting to factory reset with no success.  One of them is not even showing the power light or ethernet connection but the powerline blinks when I tried pairing!  Any suggestion would be very welcome.
CJ Davidson
Hi @cjd55 ,
You may have already tried all of these, but if not, there are some troubleshooting tips here.
Then they will hopefully be able to respond to this post within a day or two.
Hi cjd55,
Just to confirm, have you tried all of the suggestions in the below Help Article?
Fix a problem with your Network Connectors
Yes, I have worked through all of the suggestions in the help article.
CJ Davidson
Enlightened One
The one that doesn't show the power light - is it warm after being on for about 10 minutes, or stone cold? A neighbour had one of a pair which did much of what you describe, the one not showing power light was stone cold; the mains power transformer within the unit had become defective.
it is cold!  Thanks so much for this.  Now I know I need to replace it rather than just buying on spec.  Really helpful
CJ Davidson
