router loses connection
ksolan11
Message 27 of 27
hiya, for the past week or so my router keeps losing connection to the internet for about 10 secs every couple minutes making gaming impossible. at first i thought it was due to my pc being connected via ethernet cable but this was not the case. i looked at some posts and i think this may be due to the router switching channels (wifi optimisation). i've read onlu staff can disable this option. could you please turn this feature off and we shall see if this fixes the problem.
thanks
Jerzy
p.s. ive only noticed this problem when my pc is turned on
26 REPLIES 26
Message 1 of 27
Hi ksolan11
Apologies, I thought we had sent a replacement router.
If the connection does drop again then please let us know and we can send a router for testing.
Message 2 of 27
I haven't recieved a replacement router, but it has been stable the last couple of days.
Message 3 of 27
Hi ksolan11
Has the connection remained stable with the replacement router?
Message 4 of 27
Would it be the TalkTalk engineer that I should request or the Openreach one?
Message 5 of 27
Ok, please let us know how you get on.
Message 6 of 27
Thanks, I'll contact my landlord if he will pay the charges and come back to this tomorrow. I'm not sure if this is of any relevance but the last 3 days there have been no issues with the router.
Message 7 of 27
Details for potential engineer charges can be viewed at
https://community.talktalk.co.uk/t5/Articles/Engineer-charges/ta-p/2207291
Message 8 of 27
Is there a fee for the visit?
Message 9 of 27
OK thanks. We can arrange an engineer visit to investigate the disconnections. If you'd like us to do this please let us know and we'll confirm some details
Message 10 of 27
Yes, when the router was connected to the other 2 it never connected to the Internet. I'm not really familiar with these kind of things so I assumed that was normal
Message 11 of 27
So do you have 3 sockets in total and only one socket works?
Message 12 of 27
When setting up my router a month ago I first tried those other 2 sockets and they did not work
Message 13 of 27
Hi ksolan11,
Do both sockets work?
Message 14 of 27
Good Morning, I confirm its connected to the main socket, and i'm not entirely sure what you mean by extension sockets but I have these in my flat (attached below)
Message 15 of 27
Ok thanks for confirming. Is the router currently connected directly at the main socket? Do you have any extension sockets?
Gliwmaeden2
Message 16 of 27
It can still be helpful for checking the fault if you plug everything in at the master socket, despite there being no test socket, @ksolan11. However, don't fiddle with the faceplate at all.
Staff won't be back before Monday, however,  but perhaps set it up for them that way so they can run another line test when they get back to your thread on their return.
I had no test socket till recently, but was always told to plug in at the master socket anyway for testing purposes.
Message 17 of 27
Hiya
My master socket does not have a test socket, unfortunately. Changing channels did indeed not help, and when the router loses connection it sometimes does take a minute or so to reconnect but this varies as I started noticing now that it seems to be getting worse the more I use the internet where at first it takes no more than 10 seconds to reconnect. I'm not sure if using more bandwidth is also affecting this.
Message 18 of 27
I've run a test on the line now which has detected a potential fault towards the property and the connection looks unstable. Does your main socket have a test socket? If it does then would it be possible to connect the microfilter, router and phone at the test socket at the test socket so we can re-run the line test again please?
Skynet_TX
Message 19 of 27
If the LED is changing to flashing amber, then amber / white before going back to white then this indicates the router is losing connection with the internet and having to reconnect, changing Wi-Fi channels will not help with that problem. It almost sounds like you have two different issues here, as if the routers connection to the internet drops that would generally take a minute or more to come back, not just a few seconds.
Message 20 of 27
I haven't tried using a different channel so I will do so now but I won't be able to check if this fixes anything until tomorrow. When the connection drops the router starts flashing orange and then either back to white or white and orange and white afterwards
