router stand broken
dingxiwang
Message 2 of 2
Hello, all
  I pulled the router stand a bit harder probably and it went off.
I could not get it attached anymore. Any advice on how to fix it?
Thanks advance.
1 REPLY 1
Message 1 of 2
If the stand is broken, then we can replace the router for you.
I'm not able to do this at the moment as your service is not yet active, but as soon as this is active, post back here and I'll get a replacement to you.
