souper router
hi everybody
          I have just set up my new router which seems to be working ok except the ethernet indicator light is continuously flashing is this correct ???
ray
Yes, it is perfectly normal, it indicates data transfer.
Do not add SOUP to your router under any circumstances !
Martin
