souper router
4 REPLIES 4
whacker70
Hi everybody
 does anyone know if there is a limit to the number of devices ie laptop,mobile phone,tablet,ect that you can connect to the router. I appreciate the more there are it can affect your speed and can you delete the one offs
ray
martswain
Don't add soup !
Martin
OCE_Karl
I'm not aware of an upper limit to the device you can connect, albeit limited by the number of available IP addresses in the DHCP range.
The more devices the more convoluted the overall speed and performance of each device and the increased load on the router (any router).
I am aware of customers that have connected 20+ devices, although not all active at all times, things like smart switches etc that will only communicate when a change in state is requested.
whacker70
   thanks for the quick reply you've answered my question nicely
   thanks very much
ray
OCE_Karl
No Problem 🙂
