speed dropping
14 REPLIES 14
  I recently had a engineer out to fix a connection problem (needed a complete new line fitting ) and although the connection appears constantly level now my speed seems to be getting slower.
 Could someone please look into this for me please.
  thanks
Hi nickym,
I've checked the connection stats and the sync speed looks consistent. Just to confirm, what speeds were you previously receiving? Are you connected wired or wireless?
Hello michelle,
  My line should be getting between 5 -11 mbps. I've had the higher end of this in the past but now i'm currently getting up to 5.8 mbps.  I feel by keeping my line running slow i'm being coerced to move to fibre, when i do  your speed test and it pops up saying-Your broadband isn’t keeping up with you. Fix it with an upgrade to fibre broadband.
I'd be grateful if you could  please check my line to see if it may be improved.
     thanks
Hi nickym,
Current sync speed is 7.1Mbps
How many telephone sockets do you have? What other devices do you have connected in addition to your router?
Does your master socket have a Test Socket
Hello chris,
 My router goes straight to test socket. I have my PC and freesat plugged into that,which i use for netflix etc. I have used samknows to test my speed which shows up to 5.8mbps. I appreciate this is not to slow but shouldn't it be better.
  thanks.
Latency
30.3 ms
 Download
5.80 Mbps
 Upload
0.00 Kbps
Thanks for the information. Are you experiencing any problems with your telephone service, any noise on the line?
Hi chris,
 Phone line appears clear.
Latency
30.3 ms
 Download
5.38 Mbps
 Upload
602 Kbps
OK thanks.
Your sync speed is currently 7.1Mbps and error count is low. We can restart the line management (DLM) optimisation process. This may result in your connection being a little unstable for a few days but could also result in faster speed at the end of the process, would you like to give it a try?
Hello chris,  yes please do try and optimize the line for me.
   why does it say only 5.7mbps when i check via samknows and yours says 7.1Mbps ? Thanks anyways for trying to help.
Latency
29.9 ms
 Download
5.78 Mbps
 Upload
0.00 Kbps
Hi nickym,
OK, your line is now scheduled for overnight optimisation.
" why does it say only 5.7mbps when i check via samknows and yours says 7.1Mbps ?"
If this is a speed test result (throughput speed), this is always lower than the sync speed (7.1Mbps), usually around 80% of sync speed
Can you bump the thread in a couple of days and we'll check to see how you're getting on
will do, thanks.
Hi nickym
I've checked the connection stats and your line is now showing in sync at 8.3mb.
Thanks Chris/Debbie speed is better now. fingers crossed it stays as it is.
  Thank you again.
 Nicky.
Hi Nicky
No problem. Please let us know if you do experience any further issues.
Debbie 🙂
