speed problem
Emik123
Message 20 of 20
Hi guys
I have a problem with my broadband speed. Exactly at the same time 3 days in a row between 7-8pm my speed goes down to 3mbps instead 30mbps. It looks like talk talk cut speed in my area. All days is perfect. Any ideas or maybe someone has/had same problem. Cheers
19 REPLIES 19
Message 1 of 20
Can you test the speed wired.  What does a wired speed test show.
Message 2 of 20
Hello
There is still an issue. Wifi speed on picture after 8pm.
Message 3 of 20
Thanks for the update. Can I just confirm, was this a wired or wireless speed test?
Message 4 of 20
19-21mbps
Message 5 of 20
What speeds are you seeing ?
Message 6 of 20
Yes big improvement. It looks like everything back to normal last night however signal is fluctuating at this moment ( 4pm )
Message 7 of 20
Just checking in to see if there was any improvement last night?
Message 8 of 20
I've now been advised that an issue has been identified and our team are just working on resolving this. They said they will confirm as soon as the fix has been implemented.
Message 9 of 20
I'm really sorry about this. I've escalated this further as I've still not received an update on this. I will continue to keep an eye on this until I hear back.
Message 10 of 20
Another check after 8pm.
I understand that I will pay half of my monthly payment.
Message 11 of 20
Apologies. This has been raised to our Network Engineers to investigate and I've chased for an update this morning. As soon as I hear back I will post back here.
Message 12 of 20
After week my speed is still not as should be. Please see attached screenshot took after 9pm
Message 13 of 20
I've logged this out to Openreach for investigation as one of our tests is showing an issue. Check back in 48hrs for any updates.
Message 14 of 20
Hi its my speed at this moment on wifi and second picture is on wire. The worst day since 5 days
Message 15 of 20
Would it be possible to run some wired speed tests using the TalkTalk Speed Tester when the speeds are ok and also when the speeds drop and we can then pass this over to our Network Team for further investigation.
Message 16 of 20
Hi. Yes during all day is ok.
Now is 8.30 and speed is 6mbs
 second picture during day
Emik123
Message 17 of 20
Right now my speed is around 6mbps. All day is perfect.
Message 18 of 20
Hi Emik123
Just to confirm, is the speed ok during the day?
When the speed drops have you tried running a wired speed test? (with no other devices connected or in use)
The line test is clear and the line is in sync at 33mb.
Skynet_TX
Message 19 of 20
Hi @Emik123,
