upload speed only 0.0-0.1 Mbps
nttdocm
Message 13 of 13
My router didn't worked for an half hour last Friday. It works again after that but upload speed only 0.0-0.1 Mbps. How to fix this?
12 REPLIES 12
Message 1 of 13
Thanks for the update. I've checked and I can see that a fault was identified and resolved yesterday morning.
nttdocm
Message 2 of 13
The upload speed back to normal itself this noon.
Message 3 of 13
I'm sorry to hear this and please let us know once you receive the replacement router and how the connection compares.
Message 4 of 13
Hello I got a phone call form tt yesterday morning and I was told I will get a replacement router.
But my broadband didn't work for at least 5 hours since 5 PM yesterday. Very disappointed.
Message 5 of 13
Hi nttdocm
Would you like me to send a replacement router for testing?
Message 6 of 13
Hi I did this several times. Not help.
Message 7 of 13
Hi nttdocm
I've completed a line test which hasn't detected any faults and your sync speed is 79.9mb and upload sync speed is 20mb.
Please can you power down your router for a full 30 minutes and then run another speed test?
Message 8 of 13
Done. Thanks.
Message 9 of 13
  • TalkTalk Telephone number
  • we'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
Message 10 of 13
Done. Thanks.
Message 11 of 13
Hi nttdocm,
  • Name
  • Telephone number
  • Alternative contact number
Skynet_TX
Message 12 of 13
Hi @nttdocm,
Are you getting this speed test result from a wired or wireless device ?
If you log into your router to check your sync speed does this also show a very low upload speed.
Have you tried leaving the router switched off for over 30 minutes, this will ensure you get a new session when you switch it back on and may help recover the lost speed.
If that does not help it would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
