01-02-2020 04:30 PM - edited 01-02-2020 04:45 PM
Hello community. I need to help with setting up my TP-LINK router to work with tt's broadband.
I moved home for the third time. Last two times I just swapped rubbish tt routers for my TP-LINK router, just connected it to the sockets and it connected automatically. Didn't have to do anything at all. This time however router can't connect automatically.
I've tried to change settings inside router, I tried VPI, MTU numbers as tt suggested on their page, giving my number@talktalk net as login and it still can't connect. Connection status is blinking blue.
Maybe this is a case, I had to downgrade my internet from fibre to broadband because it's not supported in this area. Rubbish Huawei works here fine, but I want to use my own router.
Any help would be appreciated. Cheers!
on 08-02-2020 03:16 PM
Hi @BartasX if you look at your 7th post and slide 3 can you see the pppoe drop down if you can change this to mpoa you should be in with a chance
on 08-02-2020 02:35 PM
Okay. It can't be faulty. I was using it at my previous houses and it was working flawlessly. I was using it on last day before I moved here where I am right now.
on 08-02-2020 02:32 PM
Well I'm all out, unless anybody else comes up with anything here then I can only suggest you contact TP-Link directly. It might conceivably be faulty, you could also try connecting it on a different line if you get the opportunity.
08-02-2020 02:24 PM - edited 08-02-2020 02:33 PM
Yes, it is all the time on this mode since I started topic.
That's my actual cable setup. I don't know, maybe cables are wrong?
on 08-02-2020 02:19 PM
OK, go to Advanced > Operation Mode. Have you got that set to DSL Modem Router Mode?
on 08-02-2020 02:08 PM
VR900 manual DSL light says this. I'm struggling between flashing and off. Troubleshooting Note 1 says I should hard reset my router which I actually did and it doesn't help.
on 08-02-2020 02:05 PM
Hi @ferguson.
Tried your way, still gives me "Disconnected" status.
on 08-02-2020 02:03 PM
Hello.
Static IP gives me a lot of details which I don't know. Dynamic IP still gives me status "Disconnected". Can't find mpoa.
on 07-02-2020 02:58 PM
Hi @BartasX for some reason you need to set to mpoa, static or dynamic ip
on 06-02-2020 06:39 PM
I am at a loss really. Try it this way. Go to Basic, Internet. Try the settings there. Like this:
on 06-02-2020 06:13 PM
on 05-02-2020 11:15 PM
Doesn't work.
on 05-02-2020 10:46 PM
Try Other from the ISP list. On the next screen tick the Enable VLAN ID box and enter 101 as the VLAN ID. Select Dynamic IP as the Connection Type. See where that gets you.
on 05-02-2020 08:57 PM
I've reseted my router using 30-30-30 method and started from scratch. Quick Setup TalkTalk_VDSL still gives me disconnected status. I actually have no idea, I'm hitting the wall. Previously it was working flawlessly. But at least I can change MTU to 1500.
on 05-02-2020 05:47 PM
Hi @BartasX
Ah, not plain broadband then?
OK, start over. Factory reset the router and on the Quick Setup select TalkTalk VDSL and that should be all you need to do.
No broadband username or password needed as authentication is done from the street cabinet authenticating your line connection from the DSLAM to TalkTalk's Radius Server.
Like (below) to support me . . . Mark as solved (below) Accept as Solution
on 05-02-2020 04:43 PM
I just logged to my account and found out my package is Faster Fibre, so it must be a VDSL and not ADSL. Anyway I tried to Quick Setup TalkTalk_VDSL and putting details into Advanced settings with no result. I can't change MTU for more than 1492 (setup says 1500), can't find Transfer Mode/Loop Encaps option, Authentication and router doesn't allow me to leave username blank.
@Gondola unfortunately I'm not using landline telephone at my house.
on 05-02-2020 04:05 PM
Hi BartasX
The TalkTalk router connects ok so that's been authenticated. The Archer router was working ok at your previous property.
The DSL reports it's disconnected. So the router isn't connected to the MSAN. I'm concluding that maybe you're now connected to a different exchange that hasn't had an MSAN upgrade and the router may need a password to be authenticated at the exchange.
Call 0345 1720 049 from your TalkTalk landline; it should read back to you your broadband password. Enter that in the broadband password box at the router. See if that then connects the DSL.
on 05-02-2020 03:15 PM
I've also tried to put in everything manually in Advanced. Still doesn't work. I am using internet cable that tt provided, everything works fine on Huawei router but can't get it to work on mine TP Links. That's weird, becauseon old house everything worked perfectly and I didn't have to change anything in router. My router also worked just one day before movement, so my router can't be damaged.
on 05-02-2020 03:10 PM
Hello, thanks for answer. Flashing connection I think means it tries to estabilish a connection I believe? I don't have manual of this router anymore. It flashes for some time, then stops for couple of seconds, and then is flashing again.
Regards.
on 05-02-2020 03:06 PM
Hi, thanks for answer. I've upgraded my router because it's firmware was outdated.
Your suggestion about Quick Setup didn't help.
I've choosen PPoA, put username as landline@talktalk.net, random password and all I got is screen attached.
Regards.
