Tiscali email problem sent to Gmail
8 REPLIES 8
Clique-Al
Hi, i've just been advised that a recent Tiscali email sent a friends Gmail a/c is flagging up "RED" unauthenticated email - message as below:
Gmail couldn't verify that tiscali.co.uk actually sent this message (and not a spammer)
Can you let me know if this is a problems of TT or Google and how to resolve this issue.
Any help advice on this would be appreciated.
Thanks, Al
Gondola
Hi @Clique-Al
How did you send the email? From TalkTalk Mail via your Internet browser or via an email client or app like Outlook, Thunderbird or Apple Mail?
TalkTalk Mail will automatically authenticate the sending.
Your client or email app might not be set to authenticate the email.
 Gondola - Volunteer 2017-2020
Clique-Al
Hi, Gondola
Thanks for reply, my email was sent via client Thunderbird and have never had this issue before with my Tiscali email address. Also have had my Tiscali email for 20+ years.
Gondola
Are you connected directly to the TalkTalk network or another broadband network?
In Thunderbird, Click on View settings for this account and screenshot the Server Settings screen and outgoing server SMTP settings screen.  Image edit to obscure your email address before posting here using the Camera (Insert Photos) icon above this Reply area.
Clique-Al
I'm not a TT customer, just have a Tiscali email a/c and are connected to another broadband (ISP) network.
Thunderbird settings for my Tiscali a/c as below:
Server Settings:
Server type : POP Mail Server
Server name : pop3.tiscali.co.uk
Port: 995   Default: 995
Security Settings:
Connection Security : SSL/TLS
Authentication Method : Normal password
Outgoing Server (SMTP) Settings
Server name : smtp.tiscali.co.uk
Port : 287
Connection Security : STARTTLS
Trust this helps, also note settings have not been changed.
Gondola
The incoming server host name should be: pop.tiscali.co.uk
The outgoing SMTP server port should be 587
Other than that the settings are as recommended and so long as you're authenticating with the correct password it should be ok.
Clique-Al
Hi Gondola, just checked settings again outgoing server port is correct 587, I incorrectly wrote 287 in last post. I'll change incoming from pop3..... to correct pop.tiscali.co.uk
Will update you after test sending emails later. Thks.
Clique-Al
Just follow-up to my last post, have sent a test email (Tiscali) from Thunderbird to a gmail address I have also linked with Thunderbird and  received ok. However checking message on Gmail phone app it still flags up problem RED (?) with original post message.
What is the likely issue??????????
Gondola
Hi Clique-Al
Well, coming from the Gmail end, Gmail will flag up if either SPF or DKIM, the authentication methods, aren't implemented or fail. To see exactly what's happening you'd need to inspect the header of the email for SPF or DKIM records.
