Talktalk web page not loading on my comp, I can load any other page in a flash,
I had this trouble before, after getting in touch with TalkTalk by phone,
Hey presto a wonderful change, then slowly its got back to the old trouble,
any ideas?.
Solved! Jump to the Best Answer.
Hi @Daveyb12
You should now see the mailbox Inbox.
Hi Daveyb12
If you follow the advice and clear the browser cache and cookies then the Privacy Manager will automatically appear. But you can select the Privacy Manager via the Manage Cookies option as follows:
If there are the three grey dots that eventually time out without sign of the Inbox then first clear the browser cache and cookies. What to do if you can't load websites
Advice for Chrome browser - clear browser cache and cookies
Then try this approach for the sign in:
Before you sign in, Select the Menu icon (triple line) top right and then Manage Cookies.
Then select Accept None and when the pop-up appears select Yes, proceed.
Then enter your email address and select Continue then clear the password box and enter the password then select Sign in.
All of the above is when browser cookies appear to be holding up the sign in to TalkTalk Mail.
If the sign in is still stalled then temporarily disable Internet security software that may be scanning and holding up the sign in and or re-launch the Internet browser with extensions or add-ons disabled.
Hi Daveyb12
Nice one.
Thanks for taking time out to let us know. We always appreciate your feedback.
