I am experiencing problems with view .jpg attachments in webmail. It used to work fine and I have not changed any settings so am at a loss to understand the problem now.
Any suggestions?
Hi Kevin
I don't see a problem in viewing attached images. The images need to be in the correct format.
There are options for viewing the image, opening the image in a browser and downloading.
Select the inward facing arrowhead and that then gives details of the image file and on the right side is a thumbnail block icon to toggle an image preview giving you a thumbnail in the email detail view.
All appears to be working as expected.
What do you see? A screenshot would be good but obscure email addresses before posting.
Hi Kevin1401, keep us posted with your progress on this?
Ady
Hi Thanks for the response. It's not that I don't know how to do it. It's that when I try to open an image in the browser for example all I get is a blank screen with the timer icon whirring around. I am able to download and view but don't necessarily want to do that all the time
Kevin
Hi Kevin
If the viewing of the attachment image jpg file results in the download arrows circling and then a message indicating "Sorry there is no preview available for this image" it means the image handler association is wrong. Not a uncommon issue on a computer.
So, the resolution is to sign out of TalkTalk Mail and sign back in again to set the default image handler association and you should find the image will now display.
Please let us know how you get on with Gondola's suggestions.
Ady
