Email send problem
ANSWERED
12 REPLIES 12
fw190
Find I cant send emails from email prog today, getting :
"server reports error. the response is: 5.1.0 4iWHNh4j2OnuQZ Authentication required (TT401)"
Not sure if it is receiving messages either.
Wondering if it is something to do with new TT email thing that I have been getting all the emails about.
Been reading stuff from OCEs at the beginning of this section and info elsewhere, think everything is set up OK but our email prog does not have an 'SSL' setting, only STARTTLS or TLS.
Gondola
Hi @fw190
The error is that the email prog you're using is not using a sign in with the email address and authenticating that with a password and or not requesting authentication from the network to permit sending.  The email prog may be using an insecure unencrypted connection and for that it is absolutely necessary to request network authentication.
What's the bit of the email address after the @ symbol?
The email settings are Email settings - IMAP / POP3
What's the email prog and version? For example, Outlook 2016 or Apple Mail or another and what device / computer Operating system are you running it on? For example Windows 10 or MacOs or another?
I may need you to take screenshots of the incoming and outgoing server settings / advanced settings and to edit out the first part of the email address and then post those images here using the Photos icon above this Reply area.
Gondola - Volunteer 2017-2021
fw190
Email address ends @talktalk.net
It was working OK yesterday.
Using 'The Bat! 8.7' on Win 10 pro x64
I found some old email settings and they seem to be working with the same login details, imap.talktalk.net 143 STARTTLS.
The web mail woudn't be too bad if it didn't keep logging out all the time.
Wondering about just forwarding it and abandon the TT system.
fw190
What I entered for end of email addy was remove for some reason, it is ampersand talktalk .net
Gondola
Hi @fw190
Your email account would appear to be set up using IMAP.
When creating a user account in The Bat the settings are:
  • To access mail server, use protocol: IMAP4
  • Incoming mail server address: mail.talktalk.net
  • Secure connection: Tick
  • SMTP server address: smtp.talktalk.net
  • My SMTP server requires authentication: Tick
  • Username: (your full talktalk.net email address)
  • Password: (your normal email password)
Send mail:
  • Connection: Secure to dedicated port (STARTTLS)
  • Port: 587
Receive mail:
  • Connection: Secure to dedicated port (TLS)
  • Port: 993
fw190
Thanks for that, it says it's connecting to server but there is no new mail in the bat's inbox  but there is mail in the web mail bit that has not been received here.
Gondola
Solution
Hi @fw190
OK. It's possible that The Bat cannot immediately set up a secure connection for incoming email so change the incoming security option to STARTTLS. What should happen is that it will convert an insecure connection to secure and set up a download of the emails.
If that doesn't get the receive and send going then take and post screenshots of the settings for me in case something has been missed. Don't forget to image edit and obscure the first part of your email address to maintain your security.
fw190
Seems odd, I received notification email of your post and a couple of other things but there are 3 recent emails showing on the webmail page that have never made it to the inbox here. Update, 2 have just arrived both showing times of around 08:00.
Thanks for all your help.
OCE_Chris
Hi fw190,
So does everything seem to be working OK now?
fw190
Hi, Yes all seems OK thanks.
Been trying an old lineone account that I discovered TT took over and it still works.
OCE_Chris
That's great news, thanks for letting us know 🙂
busterboy
still not working when I send I get error 1101 comes up and 587 no such host is known
OCE_Ady
Hi busterboy, could you give us a little more to work with. What mail client are you using? What settings are you using? Does your email work if you log into webmail?
