email support
Emails from cineworld not being received
GillyB1
Message 10 of 10
Hi, I book with Cineworld regularly and until yesterday the confirmation email was received in my inbox instantly.  I have received numerous other emails, so looks to be specific to this senders.
Wondering if I’ve accidentally put a block on, but don’t know how to check, anyone know how?
9 REPLIES 9
Message 1 of 10
Ok thanks very much for posting back to let us know.
Ady
Message 2 of 10
I need to correct my last reply.
The alternate, none TalkTalk email is working perfectly. Cineworld user e-mail as user name, and I had tried to re-order a confirmation that had been booked under the TalkTalk e-mail, after changing username. Once I cancelled and re-did the booking it was fine.
So the problem is specific to TalkTalk, but I don’t need it investigating further.
Message 3 of 10
I changed passwords and booked a new film, but still did not receive confirmation.  Then I changed my Cineworld details to use an alternate email account: not a TalkTalk one.  I got all the mail regarding the account setting changes but still not the booking confirmation.
Don't now think that it is a TalkTalk issue so will go back to Cineworld. I have work round so all good.
Message 4 of 10
Hi GillyB1, please post back to let us know how you get on.
Ady
Message 5 of 10
Hi GillyB1
If you have any suspicion of unauthorised changing of settings in your mailbox then yes please do upgrade the password to an ultra strong never used anywhere else password of 12 - 15 multicase letters and numbers and a symbol.
GondolaVolunteer 2017-2021
 Like below to appreciate my help . . . Best answer is + Accept as Solution
Message 6 of 10
I have now disabled all Rules and there are no forwarding settings.
messages composed and sent to myself behave normally. I have now been to the cinema, so will not expect anything from that sender until I book again, so cannot test that until then.
I think I will change password anyway.
thanks for your help
Message 7 of 10
Hi GillyB1
If there are any Filter rules there then my recommendation is to Disable all.  We have seen hackers modify filter rules so even if you set up a Filter rule then whilst troubleshooting please Disable all.  Worth also checking that there's no Auto forward of your mail.
Test that nothing is impacting the receipt of mail in the Inbox by composing and sending the mailbox a message. Check the message is copied in to the Sent objects folder and then arrives and stays in the Inbox. If messages do not stay in the Inbox then a mail app may be collecting and deleting them.
To lock out an unauthorised mail app then change the mailbox password. Changing your email password
Message 8 of 10
Hi, thanks for telling me how to find the rules.
i only have move to folders and none should have affected the cineworld senders.  I have set up a move rule now, and asked them to resend, which they say they have.  Still nothing received my end.
Gondola
Message 9 of 10
Hi @GillyB1
Go via the TalkTalk Mail sign in check there's no Filter rule diverting your mail messages.
Main Settings menu (triple line icon top right header - mobile browser? use the desktop version) > Settings > Select the arrow by Mail / Email in the side panel > select Filter rules - if there are any select Disable or Delete.
Filter rules - Disable
Let us know if you see any unexpected Filter rules.
Advice on using TalkTalk Mail
