on 05-01-2019 05:39 PM
Here's what you can do: Contact the lineone.net postmaster and tell them that they need to change lineone.net's SPF record so that it authorizes avasout07.plus.net. For example, they could change the record to something like
v=spf1 mx ip4:62.24.135.128/26 ip4:62.24.229.0/26 ip4:62.24.135.64/26 ip4:78.144.6.128/26 a:avasout07.plus.net -all
If you refer your postmaster to this web page, they should be able to solve the problem.
Answered! Go to Solution.
on 10-01-2019 08:05 AM
That's great. Thanks for posting back to let us know it's sorted.
on 09-01-2019 08:23 PM
Thank you both for the help.
I now seem to have it working in Mac Mail. As far as I can see the emails aren't being flagged as spam now.
It was a struggle to get Mail to accept the new settings, it kept defaulting to the Plusnet settings, in the end I had to create a new account and it worked.
Next I'll try the Gmail app settings - if that works too then we're in business.
I'll let you know...
on 09-01-2019 01:52 PM
Hi John,
How are you getting on, has Gondola's advice helped?
on 09-01-2019 12:22 AM
Hi John
Apple support have a useful description of email settings. They say, most of the time Mail sets itself up correctly. But don't rely on that to be the case as many times it does not and requires manual intervention.
For Mail on a MAC here are the relevant Lineone IMAP email settings you need:
Account Type | IMAP |
Your name | John Forr |
Email address | username@lineone.net |
Password | Email Password |
Remember Password | Yes |
Incoming Server Name | imap.tiscali.co.uk |
Incoming Port | 993 |
Connection Security | SSL |
Authentication method | Normal password |
Outgoing SMTP server | smtp.tiscali.co.uk |
Outgoing Port | 587 |
Connection Security | STARTTLS or SSL |
Outgoing Authentication | Yes |
When you've put in the Account settings just close the Mail app and reopen it and recheck to make sure the settings have not been automatically changed.
Like (below) to support me . . . Mark as solved (below) Accept as Solution
on 08-01-2019 10:31 PM
I'm using Mail on an iMac.
Thanks for your help!
John
on 08-01-2019 08:07 PM
Hi John
No, don't send lineone emails as an alias in gMail as that's not going to get proper authentication.
If you wish to use the gMail app then add your lineone email account to that using the secure tiscali IMAP settings in the TalkTalk article. That will work perfectly.
Are you using Windows Mail or another Mail app?
In Windows Mail
on 08-01-2019 07:14 PM
Hi there,
Thanks very much for your help.
Those settings didn't make a lot of sense to what I see in Mail, but I will try again when I have more time.
In the meantime, I sent an email from my Lineone account as an alias within Gmail, so the Plusnet servers are not involved.
The emails are still marked as spam - the message reads:
'Why is this message in Spam? It's from an address in the lineone.net domain but has failed Lineone.net's required tests for authentication'
So it seems to be a problem with the address itself. Big problem as no-one receives emails I send!
Any ideas?
Cheers!
on 08-01-2019 06:53 AM
Hi JohnForr, I see Gondola has provided the right advice. Please let us know how you get on.
on 06-01-2019 05:20 PM
Hi @JohnForr
The answer is easy. Don't send your lineone email through the Plusnet SMTP relay server just use fully authenticated secure sending via the lineone / tiscali SMTP server.
The Lineone email settings you need are:
Login / Username | username@lineone.net |
Password | Yes |
Incoming mail server | imap.tiscali.co.uk |
Incoming Security | SSL |
Outgoing mail server | smtp.tiscali.co.uk |
Outgoing Security | SSL |
Ensure you're using plain password authentication.
Any problems setting up the Mail app, let me know of the error message and take and post some screenshots of the outgoing server setup using the photos icon above this Reply area.
