5ghz wifi password
4 REPLIES 4
I can't connect with the 5ghz WiFi keeps saying password is incorrect. I have logged into the router and both the passwords are the same. The WiFi is there as my phone can see both can log in to the 2.4 GHz but not 5ghz.
Wise Owl
Try changing the password on the 5 ghz band and see if you can connect. I assume that you've split the SSID's as you can see a 2.4 band and a 5.0 band?
Fritz
Thanks Fritz, I did not split them, I thought that if I could see both the 2.4 and the 5 on my phone they were split already but I hope you're right . i ll give it a lash
Changed password on the 5ghz band and that sorted it .....
Hi hellogreg
I'm glad to hear that this is now working. Please let us know if you do experience any further issues.
