Advice on speed boost please
6 REPLIES 6
Good morning technical team.
I would like some advice please regarding my circuit. I recently tried to re-contract my service and I was told by the adviser that they could not re-contract my speed boost as that service is not available on my line. I have been paying for this service for many years now so I do not understand. They advised I raise the issue with the technical team so please advice.
For info my router is currently showing an available rate of almost 50Mbps and is synced at 44Mbps.
Thank you.
If you are sync's at 44M, then the speed boat is active.
Hi mdph1978
Exactly as Keith says, if it's in sync at 44 then the boost is active.
To be doubly sure, I've checked your line and it does show the boost is in place.
Thanks Karl, but I understand it is already in place. I just could not understand why they could not re-contract me. At first I was told that I could retain my speed boost at half price for 18 months and then I was told that they could not apply it to my account as that service was not available on my line?
If you are only just in sync above 40mb then you may not be able to have the boost added at renewal.
New rules have come into play that will stop the boost from being applied if there is no benefit.
Thanks for confirming Karl. So if I was to drop the boost and save the £5/month am I likely to see any difference in performance? Does it affect the upload bandwidth in any way? I remember some ways back that without the boost upload was limited to 2Mbps right?
The upload would be up to 10 mb on the standard fibre and as your router is in sync at 44mb then it should sync at the full 40mb.
