Amazon Prime Buffering all the time
15 REPLIES 15
Kenton11
I have recently installed TalkTalk fibre and TV. However Amazon prime on the TalkTalk box buffers all the time. Tried to watch a couple shows (The Grand Tour) and buffers every few seconds. Ended up watching it on my IPAD without any issues. The network speed is around 30-40 Mb/s.
I have followed other threads, i.e. change resolution, reset box, etc... Still have the issue. Seems like the Amazon Prime App on the box is the issue.
Hi Kenton11,
  • Name
  • Telephone number
  • Alternative contact number
Kenton11
updated profile as requested.
Hi Kenton11,
Thanks for updating your profile but could you also add your TalkTalk landline telephone number to your Community Profile so that we can identify you on our systems
Kenton11
done. Set it as the primary phone number
Hi Kenton11,
Thanks for adding your landline number
Line test is passing and sync speed looks OK.
Can you confirm that when you run Amazon Prime on your iPad, you're connecting through your router and not connecting to a mobile network
Do you access any other streaming services via the TalkTalk box? If you do then do they run OK?
Kenton11
Yes everything runs through the router (+ wifi).
Other streaming services on the TalkTalk box work without any issues.
OK thanks,
Does the buffering occur every time you watch anything on Amazon Prime? Is it worse a certain time of day?
Kenton11
It was generally occurring on certain shows, i.e. the Grand Tour. But does not buffer on some kids shows (like Dino Dina).
I just tested it now and is not buffering at all. So seems it could affected by the time of day.
OK thanks. Could you monitor it over the weekend and let us know roughly what times you experience problems. Could you also note if you are accessing the internet on any other devices when the buffering occurs (such as another family member watching Youtube on another device)
Kenton11
Tried to watch on Friday 20:30 and buffered all the time so i ended up watching the show on my IPAD again (no buffering). Tried again now (Sunday 18:00) and is buffering all the time. IPad again having no problems using the same network.
Can you try a facory reset of the youview box from the settings menu.   The down side of this, is that recordings are erased, but this seems to have resolved the issue for some others.
Kenton11
I have done the resets before. Does not solve the issue.
There was no buffering last night (monday) on the TV so it seems this issue happens mainly on weekends.
Did you perform the maintenance reset or the full factory reset.  I've found the maintenance reset did not resolve this in the past but a full factory reset did - strange I know, but this worked for a couple of customers.
Kenton11
Hi, I have done both. Neither resolved the issue.
OK, I'm still investigating this issue, but am thinking it has to be something to do with the app itself.  No network issues are detected, with other devices working fine, then it can only be the app.
