BT Smart Hub 2
1 REPLY 1
Mr Pete
Hi Community,
Is anyone aware if the BT Smart Hub 2 will work with TT Fibre?
BT routers etc generally tend to be well made and perform very well?
I don't believe they do, but you could always try it and see. I don't know where you get that reputational view from, the BT forums would have you believing otherwise!
Are there any particular issues of concern you have with your TalkTalk router?
