Broadband speed not as promised
Hi, what I meant was that the cable and the dsl filters were the same when connectingthe wifi hub and the hg633. We are using the ones that came with the wifi hub
Hi yugocrazy,
Thanks for confirming this. Would you like us to send a replacement wifi hub for testing purposes to see how the sync speed compares and to rule out any issues with the current router?
Yes please. Thanks
Hi yugocrazy
The replacement WiFi Hub is on its way, please allow 24-48hrs for this to arrive.
Apologies it took so long, but managed to get round to plugging in the replacement. It connects at a slightly higher speed - 59 as opposed to 58, but interestingly a slower upload speed - 12 instead of 13
I guess it means that this is just the fundamental design of the new wifi hub - in that it connects slower than the hg633 - unless you think otherwise?
I'll send the other one back. Thanks
Hi yugocrazy,
Thanks for the update. Just to confirm, how long has the replacement router been connected for?
Probably only about 12 hours so far
Hi yugocrazy,
Ok thanks for confirming this. Could you bump your thread in 48hrs and we can re-check to see if DLM has increased the sync speed any further.
Bump, the connection stats are still the same. Thanks
Hi yugocrazy
I've checked the connection stats and your line is in sync at 59.5mb.
Is the router still connected at the test socket?
Yes it is, the connection stats have improved now though to 62.2 down and 13.2 up. I guess it was the router.
Thanks for your help
Hi yugocrazy,
Thanks for the update and please let us know if you need any assistance 🙂
