Broadband speed unstable
47 REPLIES 47
Chat Champion
Broadband download speeds ranging between 2.4 and 42 mbs. Carried out all usual checks including disconnecting router for 20 mins. Speed was measured at 42 mbs immediately after reconnecting but has fallen back to below 10 mbs. Could you please check the line performance.
Hi dave,
I've run a test on the line now which has detected a possible issue towards the property and the sync speed is varying. Does your master socket have a test socket? If it does then would it be possible to connect the router at the test socket so we can re-run the line test again please?
Chat Champion
Hello Michelle.
Sorry for the delay. The router is now connected to the master socket.
Many thanks.
Hi dave,
I'm sorry for the delay. Can I just confirm, did you mean that the router is currently connected to the test socket behind the faceplate or does the master socket not have a test socket?
Chat Champion
Hell Michelle.
Yes. I can confirm the router is connected to the test socket behind the faceplate.
Regards.
Hi dave,
Thanks for confirming. I've re-run the line test again now which is still detecting the same issue, however the sync speed looks consistent for 3 days. What speeds are you receiving at the moment?
Chat Champion
Measured close to router over WiFi speeds 32.26 down 13.32 up. On 2.4 GHz band. I also reported the fault to service centre and they seem to have disconnected the 5 GHz channel, I had them separated. I am not able to log into the router, presumably because the fault is being investigated. I told them on Friday that I would be persuing the fault through yourself from then.
Regards.
Hi dave,
Thanks for the update. Can I just confirm, what speeds do you get if you run the speed test wired?
Chat Champion
Hi Michelle.
Not able to run a wired speed test, only have tablet and TV equipment.
Regards.
Hi dave,
Ok, could you try switching the router off for a full 30 minutes and then run another speed test please as this will reset the current session and can often increase the throughput speed.
Chat Champion
Router disconnected for 30 mins. Three speed checks taken
32.4 down  14.3 up
88.99?? down. 13.95 up
45.15 down. 13.8 up
I will wait for half hour and recheck to see if more stable.
Hi dave,
Thank you. Could you also leave a 5 minute gap between each speed test please.
Chat Champion
Hi Michelle
Three speed checks at 5min intervals.
45.95 down. 14.06 up
46.12 down. 14.53 up
23.74 down. 13.89 up
The third reading replicates the problem I have been experiencing, good connection and then sudden buffering and loss of video connection.
Regards.
Hi dave10,
Thanks for running the speed tests. Do you have another router you can test with? If not then we can arrange to send one
Chat Champion
Hi Chris.
Have done speed checks this morning at 5 min intervals.
15.14 down. 14.16 up
11.40 down. 13.61 up
10.27 down. 8. 95 up
Have now connected a D Link router and will run checks again in 30 mins.
Best regards.
Chat Champion
Hi Chris.
D Link router speed checks.
40.78 down. 15.40 up
39.63 down. 15.38 up
49.13 down. 14.88 up
David
Big difference, is that a d-link router that we supplied?
Chat Champion
Yes, supplied by talktalk before I went to fibre. The only difference is that the Huawei has a much stronger WiFi signal.
Hi dave10,
Could you try another 3 speed tests, 5 minutes apart, on the d-link and then go back to the huawei and run another 3 on that
