Broadband speed unstable
Chat Champion
Router powered down 30 mins. Set up same as last.
2.4 G.       Down. 11.53  Up 14.53.
5 G.          Down 47.78. Up 14.9
Still unstable.
Regards.
Hi David
Is a wired speed test closer to the 60mb sync speed?
Chat Champion
Hi Debbie.
I will never know because I don't have a lap top, just tablets and TV.
Regards.
Hi David
If we arrange an Openreach engineer visit they would only check the sync speed. They wouldn't investigate slow speed to the devices.
What's the highest speed you've received over a wireless speed test?
In your previous post you say it's unstable, do you mean the connection is dropping?
Chat Champion
Hi Debbie.
Sorry but I missed your last post for some reason.
Download speed over WiFi    5G   54.7.   2.4G   25.6
This is ok with me but when I run a live Service Status test I get the message "We suspect an issue with your broadband and need to run a line test between our network and your home". I have been getting this message for weeks.
Is there really a broadband issue or is this just a hang up which needs clearing?
Regards. David.
Hi David
When you run the service test connected to the 5ghz network do you get the same message?
Chat Champion
Hi Debbie.
I thought I had answered 3 days ago but the message was obviously not recorded.
Yes. Same message ( and same again just 5 mins ago ).
Download speed 5G.  48 mg Which seems ok to me.
Regards. David
Hi David
You may be receiving this message because the line is in sync at 59.1mb but your throughput speeds are only around 48mb.
If the performance of the connection is ok then please can you continue to monitor this and let us  know if the speed drops any further.
