Broadband speed
12 REPLIES 12
My router says my broadband speed is 38.6 Mbps however, when I do a download speed test it comes as 27.2 Mbps. Please check if any setting on my line needs to be changed to get the speed the router says I should be getting.
Hi aNoori. How are you doing your speed test? Wired usually produces a better result.
Regardless of this the sync rate will always be higher than the speed test
Mine shows a sync of 73999 and a WiFi speed of 63000
It is wired directly to the router. The speed test is both from Google and Talk talk.
I had a lot problem with my line and had 3 engineer's visit to sort it. About a month ago the router speed (Sync) was 28 Mbps and the speed test showed it as 14Mbps. At the end somebody changed  some of my line parameters and the download speed went up to about the same as the sync speed. Now after one month the sync speed has gone up to 38Mbps as the line has settled with the new router and external line, but the download speed has not changed. That is why I think something needs to be changed (optimised) again.
Hi, I've flagged your post for assistance and you should hear during the day;-)
Hi aNoori,
Just to confirm, have you tried switching the router off for a full 30 minutes and then retested the speed again?
Just done it and no speed change.
Hi aNoori
Was it switched off for a full 30 minutes?
Have you also run the speed test using a different device? (running a wired speed test)
Yes it was off for 1 hour. I have connected my laptop to the router directly and then my desktop wirelessly and the speed were the same with both.
Hi aNoori
Your line is showing in sync at 36.6mb.
Do you have a different router that you can test with?
Unfortunately not. The download speed has been fluctuating during the last few days. It went up to about 38Mbps for a day or two then went back to 25Mbps for a further few days.
I have just checked it and it is around 35Mps.
Hi aNoori
I can send a replacement router for testing, would you like me to arrange this?
The router I have is a brand new Hub router received a month ago.
Do you think a test one would help? Also what was changed on the line that increased the download speed (just for my reference)?
Hi aNoori,
If the wired speeds are fluctuating then it would be worth testing with a different router to rule this out. Do you still have the original router?
