Cancelling Fibre Speed Boost?
1 REPLY 1
Anybody know how to cancel the £5 Fibre Speed Boost?
Switched to the Faster Fibre plan which already gives you the full speed, so it feels a bit silly to have to pay for a boost that does nothing.
Going through MyAccount just dumps me on the page for SuperSafe whenever I try to control my broadband boosts.
Hi YannS,
If you'd like to have the boost removed then if you contact customer services they'll be able to do this for you. But removing the boost will result in your sync speed dropping to 40Mbps
