Cannot Communicate
12 REPLIES 12
I need to contact customer services to arrange an engineer visit. How do I go about that in the current situation? I've tried ringing multiple times and tried every option on the automated service but can't even seem to join a queue. No online chat, no email address, no enquiry form. I've even tried tweeting the Talktalk Twitter account but to no avail.
Be grateful if anyone has any experience of communicating over the last couple of weeks since the 'reduced team' situation came into effect.
Hi @Ian19811 welcome to the very busy community, your post has been flagged for assistance and you should hear back soon inthe meantime please check your community profile and add your landline phone number which is used to identify your account.
What is the nature of your issue?
Hi and thank you for responding. I’ve had some building work done and the joiner has cut through my phone line. He has managed to doctor the cable and tape it up but it doesn’t seem safe and I’m dropping connection almost on a nightly basis. I require an engineer to come and reinstall/replace the cable and whilst I fully appreciate there will be a charge for this, I just want it logging...... at the moment I’m not able to even tell Talktalk about the problem.
Appreciate you replying, hopefully someone will be in touch to assist me.
Ian
same!!! 😡
Hi @amyred if you require assistance please start your own thread.
@Ian19811 now that is annoying the OCE team will pick this up and arrange the correct engineer. is the damage your side of the master socket or the outside of the socket, it influences the choice of engineer.
Thanks @Divsec
It’s the wire inside my property that goes to the master socket. It comes through a brick wall from the telegraph pole and then runs along a skirting board to the master socket.
Hopefully that makes sense, thanks again for helping me with this
Ian
Hi @Ian19811 thanks for that it'll help the team.sounds like an openreach engineer and there's the rub, they are generally not entering premises. I can think of a couple of bodge solutions but let the experts work their magic, good luck.
@Divsec ok great thank you
Shall I expect an email or a call from the relevant team then whenever the current restrictions are lifted/changed? Or will a ticket/job be created straight away and it’s just a case of waiting until Openreach change their current policy and start making appointments again?
I don’t mind waiting as long as it takes and paying whatever it costs, I just want it sorting.
Thanks for reporting this for me
Much obliged
Ian
Hi @Ian19811 the Talktalk team are very active in here and will sooner or later arrive at this thread and advise you of what they can do.
I was just browsing Amazon for replacement master sockets which require no special tools, under £ 10 which surprised me.
Ok hopefully someone sees it and it gets picked up.
Thanks again
Ian
Hi Ian
Openreach have advised all providers that any install or any fault where the engineer has to enter the premises will not be actioned until June.
This is not something we can bypass and must wait for their restrictions to be lifted.
Thank you @OCE_Karl
So has my issue been logged and someone will be in contact when the restrictions are lifted to arrange an appointment or do I need to simply wait until June and try to make contact again?
Will Talktalk staff be back to answering the phones again in June?
Ian
You can contact us nearer the time.  It could be sooner if the situation changes, we just don't know at the moment.
You may be able to source a local telephone engineer at of the local paper / phone book etc who could do the job.
