Cannot connect to WiFi but hub is working
4 REPLIES 4
I've moved home and my line has been activated. The white light on the hub is on and @WiFi is detected on my mobile phone. It connects but then an error sign appears and says require sign in/authorisation. If you press on this it attempts to load a website but says I don't have permission to view the page! Any help would be great as I've tried restarting etc and nothing seems to be working
Hi @sophieoh123 ,
This authorisation error is a common problem when people move home, the staff here will be able to look into this for you, they will hopefully be able to respond tomorrow.
Hi Sophie
Could you add the home phone number to your profile rather than the mobile, and I'll check the connection for you.
Hi I have added my home number thanks. Internet was delayed a day according to an automated message but it is 24 hrs later and should be good but I'm still getting the same message when I try to connect.
Sophie
Hi Sophie
The line test has detected a possible fault with the landline service. Do you have a dialtone, can you make and receive calls?
