Cloud gaming
7 REPLIES 7
Sightseer
Hello so I live with my family and I cloud game using a service called shadow and am experiencing packet loss after troubleshooting with shadow and mods from there discord they say that I have a congested route causing the packet loss I'm not the account holder but am wondering how talk talk can deal with route congestion and is it possible someone could help without doing anything major like engineer visits it's just nobody in my home understands how the network works etc.
Many thanks
Hi @ShadowGamer your post has been flagged for assistance and you should hear back soon.
In the meantime please check your community profile and add your landline phone number which is used to identify your account. Click avatar top right corner then settings, then wizard. Please don't post personal details here for security reasons
Hi ShadowGamer,
I'm sorry to hear you're experiencing problems with your service, can you please update your community profile to include your:
  • TalkTalk landline Telephone number
Sightseer
Hey I'm not the account holder but I use the network so you won't do anything without consulting me because my family don't want engineer visits and I just want to keep everything on this forum
Yes we can just check your connection stats etc. but we need your landline number to locate your line on our systems
Sightseer
Just updated it  can u just check how it is then put your findings on here and please don't do anything further until I have said it's ok thanks
Thanks for that. Line test is passing and sync speed is good. Can't see any issues. There was a profile change on the 1st July
Has it worked OK in the past?
How long have you been experiencing this issue?
Do you experiencing issues with anything else?
Sightseer
@OCE_Chris  I have no other issues I just have packet loss on my cloud gaming service (Shadow). I contacted the cloud service support and they said it's my network. I also saw people with the same issues on BT and Plusnet and they were given a order for a super stable Service and someone got their NGA profile changed to stability which solved there problem. Is there anything like this u can request/order for me please or anything you can apply to my connection that i can test to see if their is improvement?
Hope to hear from you soon
Many thanks
