Connecting another router
10 REPLIES 10
Hi, is it possible to use the TalkTalk Wifi Hub as only a modem, and to connect a separate router to it? Is it as simple as connecting the two using Ethernet, with the cable inserted into the WAN port on the new router?
Theo
TT Hubs and routers cannot be set to work in modem mode.
Martin
Is it still possible to connect the TT Hub to the new router and use it? Thanks
Theo
You can configure a spare second router as an access point, but it will have to be connected by LAN cable (LAN to LAN port) and a few settings changed on both.
What exactly are you trying to achieve ?
Martin
Hi Martin,
I've been having a lot of issues with my TT Hub over the past few months with some very large and frequent spikes in latency. I have had no follow up from anyone at TalkTalk after months of trying to get it sorted. So I thought buying a separate off brand router may fix the issue.
Theo
Hi Theoo,
I'm sorry to hear this. Do you experience the latency when connected wired or wireless?
Hi Michelle, I experience latency issues on both Wired and Wireless connections
Theo
I should also mention that I have already done ping tests, tracers etc. They came back fine. The conclusion that was reached on my other attempt was a new router, but one was never sent.
Theo
Hi Theoo,
Ok, would you like us to send a replacement router for testing purposes to rule this out?
That would be greatly appriciated
Theo
A new router is on the way for testing.
This should arrive in the next 24-48 working hours.
