Connection loss
7 REPLIES 7
Livingstonenow
A few minutes ago I experienced a loss of connection, When I looked at the log this is what I see for the period of the outage:
21.06.2019 15:52:51InfoSYS
TR-069 connectivity to (acs.talktalk.co.uk) has been closed
21.06.2019 15:52:49InfoDHCPC
The WAN DHCP client IP address 92.19.14.246
21.06.2019 15:52:16InfoDHCPC
The WAN DHCP client process has successfully been launched on Vlan 36
21.06.2019 15:52:15InfoXDSL
VDSL connectivity is up port 1
21.06.2019 15:51:46InfoXDSL
VDSL connectivity is down port 1
21.06.2019 15:51:46WarningDHCPC
The WAN DHCP client process has successfully been terminated on Vlan 36
Could you tell me if these log entries tell you/me why the connection failed and what each entry actually means please. Thanks
I8this
@Livingstonenow
I cannot be of much help to you with most of this, but 92.19.14.246 is:-
92.19.14.246 IP address Information
The IP address 92.19.14.246 was found in Watchet, Somerset, United Kingdom. It is allocated to TalkTalk. Additional IP location information, as well as network tools are available below.
IP address:92.19.14.246
hostname:host-92-19-14-246.as13285.net
ISP:TalkTalk
City:Watchet
Region:Somerset
Country:United Kingdom (GB) flag
Postal code:TA23
latitude:51.1624
longitude:-3.353
inetnum:        92.16.0.0 - 92.23.255.255
netname:        CPWBBSERV-NET
descr:          Carphone Warehouse Broadband Services
country:        GB
admin-c:        GJB18-RIPE
admin-c:        PM58-RIPE
tech-c:         GJB18-RIPE
tech-c:         PM58-RIPE
status:         ASSIGNED PA
mnt-by:         OPAL-MNT
created:        2007-06-29T11:58:45Z
last-modified:  2007-06-29T11:58:45Z
source:         RIPE
person:         Gareth J Bowen
address:        TalkTalk Communications Limited
address:        Soapworks
address:        Ordsall Lane
address:        Salford
address:        Manchester
address:        M5 3TT
address:        United Kingdom
phone:          +44 161 2222000
fax-no:         +44 161 2222003
nic-hdl:        GJB18-RIPE
mnt-by:         TALKTALK-MNT
created:        1970-01-01T00:00:00Z
last-modified:  2019-01-25T16:11:00Z
source:         RIPE # Filtered
person:         Phill Magill
address:        Northbank Industrial Estate
address:        Irlam
address:        Manchester
address:        M44 5BL
phone:          +44 161 222-2000
fax-no:         +44 161 222-2008
nic-hdl:        PM58-RIPE
mnt-by:         OPAL-MNT
created:        2001-09-28T15:14:24Z
last-modified:  2011-07-15T10:45:41Z
route:          92.18.0.0/15
descr:          Opal-Net Autonomous System
origin:         AS13285
mnt-by:         OPAL-MNT
created:        2011-03-03T14:07:32Z
last-modified:  2011-03-03T14:07:32Z
source:         RIPE
If case you have forgotten the Do’s and Don’ts. There are members that have. Remember:-Be yourself and tell it like it is,. Be courteous to other customers. Give others the benefit of the doubt. Update your community profile. The Forum Guidelines apply to ALL members there are/should be, NO exceptions.
Hi @Livingstonenow
The logs don't say why the link went down, just that it did. Do not worry about the IP address 92.19.14.246 is probably just the assigned WAN IP address.
Livingstonenow
Thanks Keith. I've lost connection this morning too and posted a new thread topic but inadvertently placed it on the Broadband menu rather than this Fibre Broadband section - I hope that doesn't upset anyone!
The OCEs will hopefully deal with this on Monday now. Assuming that the other thread was the one I notified you about that I have moved out of the way, that is fine. Let's just stick to this one thread for this issue, otherwise, it can lead to confusion/delays.
OCE_Debbie
Hi Livingstonenow
Apologies for the delay.
I've completed a line test which hasn't detected any faults but I can see some re connections on the line. DLM has changed the profile a few times on 19/06. 21.06. 23.06 and 24.06. This would account for the re connections on the line.
Livingstonenow
Thanks Debbie. Fingers crossed........................!!
OCE_Debbie
Hi Livingstonenow
No problem, please let us know if you do experience any further issues.
