Constant disconnects
13 REPLIES 13
Jcooper1459
Since being with talk talk (roughly a month) I keep seem to be getting constant disconnects from the internet. The wifi remains on and connected to all devices but with no internet connection. When the issues happen the router flashes amber for about 2 mins after which it reconnects and goes back to a permanent white. This usually happens in 1 to 2 hr periods followed by 4 to 5 hrs of no disconnects. It is very frustrating.
Is it possible for someone to test my line and/or help in anyway.
This might be a line issue. I have asked one of TalkTalk's OCEs to pick your thread up and investigate it for you.
Hi Jcooper1459
  • Name
  • Telephone number
  • Alternative contact number
We'll then look into this further. Please do not post this information on this thread Once you've updated our profile please post in your topic to confirm it's updated.
Jcooper1459
Debbie,
This has been updated.
James
Hi James
The line test has detected a possible fault. Can I just check if your landline service is working ok when making calls? (any noise)
Is your router currently connected at the test socket?
Jcooper1459
Debbie,
Phone works fine with no issues and a solid dial tone.
What do you mean by test socket? The router is plugged into the splitter (1 line to phone and other to router). The splitter is the connected to the connection in the wall. There is only one socket in the wall.
Hi James
Would it be possible to post a photo of your master socket?
Jcooper1459
Debbie, please see above. Thanks
Hi James
This socket should have test socket behind the lower section of the face plate. Would it be possible to connect the router at the test socket using a microfilter?
Jcooper1459
Debbie, it is now connected as shown. Is this correct?
Hi James
Thanks, that is correct. I have completed a further line test which is still detecting a possible fault, apologies for this.
I have passed this fault over to our Network Team for investigation. Please can you post back on this thread in 24hrs and we can check for further updates on this fault.
Jcooper1459
Debbie,
Still having a lot of issues and disconnects here (I get about 3 mins connection time every 10mins or so). This is starting to become a real problem as the internet is not usable, I need to have a stable connection for my work (especially on weekends). It is quite often simply a flashing amber light, followed by a flashing amber and white light and finally a solid white light when it reconnects.
Having said that yesterday afternoon there was a pretty good connection for 8hrs or so.
Can you please look into getting this sorted ASAP, I am struggling here.
James
Hi James
Apologies for this.
I have requested an update on this fault from our Network Team and I will post back on this thread as soon as I receive further information.
Hi James
This fault is under investigation with a BT Openreach line engineer and we should receive further updates within the next 48hrs.
