Constant reboot of router.
8 REPLIES 8
Fspencer
In order to retain a normal service, I have to reboot the router at least once a day. Before reboot the talktalk speedtest shows a download speed of 1-2Mbps. After reboot, the download speed goes up to the normal speed of 20+Mbps. The problem is on both direct ethernet connection on my pc and wifi connections with other devices. I have done all the tests shown on the service centre webpage and there are no issues found. This seems to be a recurring problem on this forum. When are Talktalk going to sort it out? I'm getting very frustrated, to the extent of considering changing provider after over 10 years of pretty much trouble free service.
Fred S
Skynet_TX
Hi @Fspencer ,
For one of the TalkTalk staff on this forum to be able to look into this you will need to update your community profile to include your name, landline telephone number that your TalkTalk service is provided on & an alternative contact number. This will allow them to identify you, and they will then be able to help.
The staff should be able to run some tests on your router, and if they believe it is faulty they would be able to send you a replacement.
OCE_Debbie
Hi Fspencer
  • Name
  • Telephone number
  • Alternative contact number
Fspencer
I have now updated my profile with the information requested. Do I need to do a new post?
Fred S
Fspencer
All information now entered into my profile.
Fred S
Gliwmaeden2
Staff reply during business hours Monday-Friday,  @Fspencer
OCE_Debbie
Hi Fspencer
I have ordered you a different router for testing, please allow 24-48hrs for this to arrive.
Fspencer
Hi Debbie, I received the new router on Wednesday and I haven't need to reboot it so far. Thanks for all your help and assistance.
Best regards Fred S
Fred S
OCE_Debbie
Hi Fspencer
I'm really glad to hear this. Thanks for letting us know 🙂
