What should I do if I lost the sticker at the back of my Dsl 3782 router? I forgot my wifi password.
Please help.
Factory reset, login with default password and take it from there.
https://www.router-reset.com/info/D-Link/DSL-3782#factory-default-settings
Thank you for that. How about the wifi hub black. May I know how to change the network username and password that says 01warehouse?
Hoping for your immediate response.
Manage advanced settings > System management > Account management
You can't change the username "admin"
Hi Heaven1
I'm sorry for the delay.
Do you still need help with this?
Hi Heaven1
Please can you factory reset the router using the pin hole reset for ten seconds and then follow the steps in this help page
Thanks for your response but I'm referring to wifi hub black, where to check the network username and password that says '01warehouse'
Hi Heaven1,
Could you update your community profile to include your:
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
