Day 1 - Perfect, Day 2 - Off to a rocky start......
53 REPLIES 53
Day 1 and everything worked great.  Last night the router seemed to have updated the firmware and GUI, but this morning several drops on the DSL.  I know there is expected to be some "settling" but so far a stark difference to yesterday and the speeds are little slower on download and down 40% on upload.
The router logs are difficult to read, is there anyway to just see the times the DSL goes down without paging through all the data ?
Update - 6 disconnections in less than 30 mins, not sure what has changed this morning, any ideas ?
Still dropping with some frequency.  How can I get the attention of the TalkTalk team to take a look.  Only change has been the update on Firmware that was pushed to the router last night.
Update - 23 disconnections so far today........
So, I received a text from TalkTalk (unprompted) to say an engineer is being sent as my service was not operating at the expected level.  Excellent customer service !
5 drop outs so far today, engineer has since come and gone, so lets hope it's solved.....
Hi Kssquared
Apologies for the delay.
How has the connection been since your last post?
Thanks for the post @OCE_Debbie
Summary thus far:
Day 1 - 0 dropouts
Day 2 - 23 dropouts
Day 3 - 7 dropouts before engineer & 5 after visit
Day 4 (today) - 4 dropouts since midnight
Speed is good, but something is still not right.
Hi Kssquared
The line tests are all clear. Have you tested with the Huawei WiFi Hub?
@OCE_Debbie I only have tried the Sagemcom router that was supplied.  I do have my own TP-Link Archer 2800 if you think I should try that ?
Hi Kssquared
I can send you the Huawei WiFi Hub for testing or you can test with your own router.
Please let me know if you would me to send the router for testing.
@OCE_Debbie Thanks.  I can try my one to see, but I'm not sure if its coincidence but day 1 was good and the only thing that changed was the firmware.  Can you roll back the firmware to SG4K10001400t ?
Hi Kssquared
Unfortunately we are unable to roll back to older firmware versions, apologies for this.
@OCE_Debbie What about sending me the digital file and I manually update it here ?
Hi Kssquared
Apologies, we don't send out files for firmware updates.
@OCE_Debbie OK, I can try my TP-LInk tonight, will I need a username & password ?
Just to advise in the last hour I haven't dropped out but my Skype/Teams calls have been terrible only hearing every other word.
No user name and password is required
No username or pwd required
Broadband settings
1. Select the transport mode.
Transport Mode: PTM
2. Select the line mode.
Line Mode: Auto Select
3. Set the MTU value.
MTU: 1500 (1-1500)
4. Enter the VLAN parameters.
VLAN ID: 101 (1-4094)
Priority: 0
WAN Settings
ISP Protocol: DHCP
2. Enter the ISP host name and domain name (optional).
Host Name: (leave blank)
Domain Name: (leave blank)
3. Select the DNS type.
Hi Kssquared
This help page should help when setting up your router.
Set up a non-TalkTalk router
Thanks both for the info.
@OCE_Debbie I've dropped 4 times in the last 30 minutes.  What else could we explore as I doubt the router is the issue, although I will try it tonight ?
Hi Kssquared
Apologies for this. If the connection is dropping with 2 different routers at the test socket then the next step will be to arrange an Openreach engineer visit.
