Disable UPnP
Hi Tom,
Could you run a wired ping and trace route and post the results into the thread so we can see how they compare?
Run a Ping or Traceroute
Hi Keith,
Are you able to provide an estimated date for when the option to disable UPnP will be made available?
I find it baffling that TalkTalk would remove the option while knowing the security issues associated with UPnP. I also know for a fact that my old TalkTalk router (HG633) did have option.
Many thanks,
Lorik
Hi Michelle
many chance you could disable my upnp please?
many thanks
Hi Pricey1989
I'm sorry for the delay. Our Products Team have advised that we can't remove this.
Hi.....did you ever manage to get this sorted out? I have got the same problem but talk talk live chat don't even know what UPNP is!!!
Hi Debbie,
In the following post (https://community.talktalk.co.uk/t5/Broadband/Switch-off-UPnP-on-Sagemcom-FAST-5364-router/td-p/2442...), the products team did indeed disable UPnP, can you please confirm the steps I need to follow in order to have the option disabled on my router.
Thanks,
Lorik
After logging in to the router web interface, press F12 for a console and copy in the following before pressing enter to disable UPnP:
$.xmo.setValuesTree(false,"Device/UPnP/Device/Enable")
Or the following to re-enable UPnP:
$.xmo.setValuesTree(true,"Device/UPnP/Device/Enable")
