Disabled wifi on talktalk hub
44 REPLIES 44
chirag_patel_105
Chat Champion
Hi i have seen others have had a similar issue with the router i have no wifi it has been disabled i have tried to factory reset it and still does not work. I have wired connection only. Please can a new router be sent out ASAP
OCE_Debbie
Hi chirag_patel_105
Apologies for this.
chirag_patel_105
Chat Champion
Thank you
Will the router be the same as the one I have tge newest router
OCE_Debbie
Hi chirag_patel_105
Yes this will be the Wifi Hub.
Debbie 🙂
chirag_patel_105
Chat Champion
Thank you
I will let you know what happens next
OCE_Debbie
Hi chirag_patel_105
Thank you 🙂
chirag_patel_105
Chat Champion
Thank you for sending the replacement router wifi is back up and running now thr the only thing is tge speed has dropped to 43mbs from an average of 55mbps
What should I do
OCE_Karl
You can try turning the router off for 30 minutes.  This will end the current session and allow a new session to start when you turn the router back on.  Give this a try.
chirag_patel_105
Chat Champion
I will give that a try later in the afternoon see what happens and i will keep you updated
OCE_Karl
No Problem 🙂
chirag_patel_105
Chat Champion
I left everything off for 1and half hours speed down is 44. 2 and up is 19.6
Used to be about 55mbps uo is perfect down is not
OCE_Chris
Hi chirag_patel_105,
Thanks for trying that. I can't see any indication that anything has changed on your line, you're still on the same profile. Are you using all the new kit provided with the new router?
chirag_patel_105
Chat Champion
I have used everything new including the adapter but the download speed is still not going up.
Last time this happened a OpenReach engineer came out and reset the line.
OCE_Chris
Your line profile isn't limiting your speed to 44Mbps so resetting DLM probably wouldn't improve your speed
How many telephone sockets do you have?
Does your master socket have a Test Socket?
chirag_patel_105
Chat Champion
I only have one socket and it is a pre filtered socket the newest master socket it was fitted by the engineer last time as he broke my original socket so he replaced it fully.
And i only have one phone connected to it.
OCE_Chris
Thanks for that. Could you try connecting the old router again, just want to see if this results in the sync speed improving
chirag_patel_105
Chat Champion
Unfortunately i can't as it has been sent back to talktalk because it was faulty
OCE_Chris
OK thanks. Could you switch your router off and leave it off for 30 minutes then before you switch it back on can you disconnect your telephone. Could you let me know when you've switched it back on and I'll check your stats
chirag_patel_105
Chat Champion
Ok i have turned it off and will remove the phone line connection in 30 minutes
OCE_Chris
