Disconnections every few hours
I started with TalkTalk faster fibre on 15th May and ever since I have been getting the router disconnecting and reconnecting several times a day. It seems to happen at least once in the evening and again in the morning - around 10AM and 10PM I think. But it also happens at other times during the day. I use the broadband to connect to my companies intranet via VPN and the disconnects cause that to drop and all the session state I have on the remote servers to be lost.
I read that this could be TalkTalk using TR-069 to tweak my router but I thought that was only for the first 14 days.
This is a real problem.
TalkTalk support chat said they couldn't help and I needed to post to the community and hope OCE picked it up.
My router is the new sagem model.
Hi mm33741
All tests are clear and I'm not seeing any drops in the sessions.
DLM has settled and the last profile change was on the 2nd.
TR069 is an underlying layer that is always active to pull performance data from the router so this should not cause the router to physically drp the connection.
When the connection drops, does the light on the router stay white or go amber ?
If the drop mostly occurs when using VPN, try logging into the router and changing DNS to 8.8.8.8  &  8.8.4.4
